p0267
got a mk6 fiesta 1600 i have fault code po267 i have replaced the coil  plugs leads pcv and pipe and battery i have replaced injector number 3 still no change missing under load if i am light on the throttle it good any one had same problem???
Have you checked for injector pulse on cylinder 3?
No I have a spare wiring loom I think of take in manifold off to see if any damage to it and replace gasket  I will test pulse tomorrow thanks
I wouldn’t touch anything until you’ve tested the injector wiring, afterall it is a circuit code.
