reversing lights failure
on my transit mk7 I noticed reversing lights are not working, changed bulbs, checked fuses and checked switch on gearbox. I tested plug for switch and noticed I have no power going to plug so I'm assuming it is a wiring fault. looking for a wiring diagram for transit as maybe need to run another supply to rule it out or fix it hopefully. any info would be greatly appreciated.
What year is your transit?
I would double check fuses, esp fuse 33 in engine bay fuse box if you have no power to switch plug.
thanks Ian, double checked and their is power at no: 33,may be a faulty plug. I will try a new one and test wires between fuse and plug.
