Pedal swap
Hello, just a quick question on accelerator pedals. Will the accelerator pedal from a mk6 ST150 fit in a mk6 zetec blue edition 1.25 2008, if so would it be a simple bolt on and connect?
Thank you
Yes it will fit, but the ST150 pedal has a chrome pad where the standard pedals are just black.
Cheers for the reply, the pedals in my car have worn down so there's no grip. The st150 pedals look a lot better and appear too have more grip so I will get the pads and the accelerator pedal.
Cheers
The ST pedals have less grip...  Honestly I've never had another set of such slippery pedals when wet!  :laugh:
Really? Luckily I haven't ordered any yet, I will probably but the normal black plastic pedals instead then.
Cheers
@Arkhangelsk1989 swapped my zetec s pedals and put ST ones on mine. Don't really noticed a difference in grip / slipperiness.
Before _20190410_180753.thumb.JPG.a1a84a992f3423455a9d6f8e6903f6e6.JPG_20190410_180815.thumb.JPG.f730c42cc58fac363bbcd326d6d0ae99.JPG
After_20190410_180853.thumb.JPG.10729f94559f8871abe4dcaedef63812.JPG_20190410_180837.thumb.JPG.aaf7f38baa1759b423f4b92effd7aafd.JPG
They look miles better than the standard black plastic ones, might get some
Cheers mate
Cheers mate
When putting the ST pedals on, use washing up liquid as it helps slip the pedal slot into the metal bit of pedal. The ST pedals aren't as flexible as it has that metal front so do recommend you lubing it.
They may not look much but honestly transform the interior.
Quick question, does installing the St accelerator pedal make the pedal more sensitive, is the pedal more sensitive than the old plastic one?
Thank you
Thank you
No there's no difference.
  • 8 months later...
Quick question, do you need to calibrate the pedal after you install the new ST pedal?
No, straight swap
Yep it's just a straight swap. You might find that the accelerator pedal feels hard to push in by hand but that's actually normal. Something I fooled myself with when playing with it whilst it wasn't on the car 😂
I changed my accelerator pedal cover to the chrome one from an St on my old ford focus. I found I didn't have to change the full pedal, I just unclipped the steel cover from the St pedal and it was an exact fit onto my existing Focus pedal. Just had to manipulate the metal retaining tabs to remove and refit.
  • 2 years later...
Any help on Fiesta MK 7 Accelerator Pedal Cover replacement? The cover seems very ‘attached’ to metal? Is it a case of just levering off?
