Air Con not working
Seems like you have a slow leak. Once the pressure drops then the compressor will turn completely off to prevent damage.
  • 3 weeks later...
The ac clutch seems like it is engaging when I turn the air conditioning on, its just not cold air
Thanks, i have a fault code b1a60 humidity sensor and I've found out online that this can upset the aircon operation so I replaced it hoping it would work but still no ice cold air. I read the pressure and it was 243kPa with the engine off and 279kPa with the engine running. They do have a common issue with leaks on the mk3, like the condenser, but funnily enough, the ac clutch is spinning up fine
