sync 3
still getting used to my sync 3, do I need to plug in to USB, to use my spotify on my android or should I be using bluetooth?
My spotify only works when the USB lead is plugged in, in fact I can only get access to my apps when plugged in.
thanks thought so? is there anyway of changing the wallpaper on the screen?
Not like Sync2, no.
This is your option-
Changes done via the test menu are only temporary so if you want the themes to be permanent then you need to change hex codes using forscan.
Sent from my SM-G965F (S9+)
