Activation end ON CRUISE CONTROL HELP in PCM
Hello everyone, everything good? My Ford Focus is a Brazilian model with this information: C307 FSAO, 1.6L Duratec Ti-VCT ffv-sigma.
GLX 1.6 with manual transmission.
Using the ELMCONFIG with elm327 usb scanner, I was able to activate the Cruise Control options in GEM and HEC, but I can not get PCM in any way,
check the speed control option, I believe that this option is used to keep the the desired speed option and also, it should activate the display on the panel.
If I am wrong, you can correct me.
Can anyone know for sure that 1.6-liter models with manual gearbox were not designed to have Cruise Control?
Is there any video that master how to put?
Another great doubt is that my Ford Focus 1.6 does not display the information in the field Firmware number and Module Type,
when I read on ELMCONFIG, does my Ford Focus 1.6 come with the PCM module installed?
Your type of PCM is most likely not supported by the Elmconfig software.
The Elmconfig software was developed Years ago for Russian/European vehicles. Vehicles produced for other markets are usually (a bit) different. If your PCM is not supported by the Elmconfig software you need a different diagnostic system to activate the Cruise Control functionality. Possibly the Forscan software supports your PCM but there is only 1way to find out.
