Enabling Paddle Shifter mode even on D Focus mk3.5 2016
Hi all,
I'm wondering as i got a lowest spec Focus that comes with Gear knob shifter, I have done the wiring for the cable and the Paddle shifter (I swap it out for a Kuga Wheel with cc and paddle shifter.).
But it seems it only works in S mode.
If I'm on D mode I'm unable to up or downshift in D.
While the high spec's one could be control freely even on D mode.
Is there any setting in Forscan I need to change?
Having a MK3.5 1.5 Ecoboost here.
Thanks in advanced! 😀
You should be able to change a setting to enable this,but it is only permanent manual change in Sport mode. If you select a gear when you are in D it automatically switches back to auto after 3 seconds.
Hey Dave, Do you reckon it could be enable thru Focccus? I can't seem to find such setting though..
I wouldn't know.
You may be able to do it with Forscan but you would need to know the correct code for PCM
