Help with GPS Module
Do any of you clever people out there know what the 6 pins are on the GPS module DE8T 19H463 DC? I am preparing to fit a Sync 2 into my focus, but there is no connection for the module in the head lining. I was hoping either to get the wiring harness from a donor car, or maybe just get the connection and splice it into the loom behind the radio (if this is possible).
Pin 1 12v feed, pin 6 earth. Pins 2 and 3 medium speed canbus  pin4 and pin5 not used.
That's great. Thanks Iantt.
I might try to solder direct onto the pins. I don't suppose you know which is 1 and which is 6? Also, are the Cambus + and - sensitive or does it not work like that?
Canbus+ is pin2   - is pin3
Thanks again Ian. Your a life saver.
