Help
Hey,
Can anyone tell me how I can make the part in the attached images more secure? (under the cubbyhole) As you can see it's coming out a bit more and more.
Thanks!
The weight of the Sync module attached on the top seems to weight them down. You could zip tie the Sync module to the wiring loom and try bending the kick panel back into shape. There are also plastic versions that were available on some models but I’m not sure they are interchangeable.
Okay thanks, I'll the zip tie method, thinking that's an easy fix. Since it's not visible.
Thank you!
It should hang pretty tight as long as it's seated correctly. It seems more to me like someone (e.g. previous owner) had dropped the panel perhaps for resetting the sync module and didn't put it back exactly where it should be.
Reseating it correctly should help. Can take a bit of fiddling especially if you've got extra stuff there (e.g. hardwire kit for dashcam).
Yeah honestly it's doing my head in just looking at it like that!
I'll fiddle around and see what I can do about it and get back with possible updates.
