Fiesta mk7 zetec s petrol
P2176 throttle body not learned, put throttle body on that ive just taken from working car, revs to 1500, cog light on but no eml, fuel circuit open/closed loop error, any ideas cheers
You need to make the car re-learn the throttle body position.
Turn the key to ignition (don't start the engine). Wait 1 minute, then switch off again and should be good to go. Don't touch the pedal for the duration, but hope that would've been obvious lol.
Think ive done this, i can hear clicking from throttle body snd cam sensors.
Still not out of limp 😞
Needs a scan by the sound of it. Could be more than one issue?
Just used forscan and it come up with p0562 system voltage low
Have you checked the battery voltage with a multimeter and made sure its charging properly?
If so clear it and see if it comes back
