Hesitation / chugging when going uphill
Hello
Does anyone have any idea about these error codes? Found them from the secret test menu.
Ford is 2008 1.4 tdci
P203a
P0150
P0244
P0248
P0505
P1101
P133C
P133A
P1630
P1941
P203A
Not sure if all of these are error codes as the secret menu is not very descriptive.
I initially thought it might be the diesel filter, but i saw in the service papers that it was replaced last year, so not so sure anymore.
reading the codes for the first time does tell you a lot as codes can be there for a very long time from previous problems that no longer exist. All codes need to be cleared, then drive it and see which ones come back. It's a shame cars don't record the dates with the codes.
I had the codes cleared when I got the injector seals fixed three months ago. So they should all be fairly new. Also, none of these codes where apperant when the mechanic cleared them. Only two injector related codes was stored in the system at that time.
The car seems to only chug when its warm and when under extra load, such as going uphill.
It happenes at about 2300 rpm if that matters.
Car has 74K km on the clock.
I dont know if these codes are even real. Went by the dealer, and they said there were no codes. Strange.
They said the problem might be caused by EGR, MAF, O2 or injectors. Dont know if there is any point having them do testing before an error code is registered?
Fuel filter and air filter is recently changed. I changed the air filter today but it did not solve the issue.
