2009 Focus Zetec question. Date & temperature display
I have a December 2009 Zetec but when setting up the date, it runs from 2000 to 2009 and not beyond 2009. Anyone know if there's a fix for this or do I run 10 years behind! Also the temperature reads in fahreinheit, I want it in centigrade but there doesn't seem to be an option for this? or is there? Thanks guys.
what radio does it have ?
the standard cd6000 or sony DAB all can select time /date without any issues, if u had one with sat nav there are big updates to the firmware (operating system) out there
the column stalk one side allows you to change the display on the instrument cluster to degrees C and MPG or Litre and F if strangely inclined
Not a Sony so I'm guessing it's the standard radio, no satnav. The display on the instrument cluster does all you say except centrigrade/fahreinheit, I'll have another fiddle with it and see if I've missed something?
Set the date on 31-12-2009 and the time on 23:59. Wait just 1 minute and you will be able to set the date to the current date.
