Cooling fan and heated windscreen failure following 3 year service
2015 Fiesta 1lt Ecoboost had its 3 year service and the next day I noticed both the cooling fan and the heated windscreen aren’t working. I’ve checked the fuses and swapped the relays over and still nothing. The AA couldn’t resolve the issue and suggested perhaps the fan motors shot.  Any ideas would be appreciated
Heated windscreen won't work with low battery charge so if it was shifted around the workshop and ignition left on for a while the battery may be a bit low.  Fan also takes a high current so may be the same but I've not heard of that failing due to battery before.  Assuming it's a stop start model, is the SS working ok?
Thanks for the reply
The Start/Stop is working as well as the rear heated window.
