2007 Ford fiesta Abs pump
Hi I have recently had the ABS light come on I scanned for the code and it suggests that the pump module is the culprit I haven't done much else but change the 30A fuse and it just keeps blowing it so my next steps are to check the connector to the pump and check all the wiring assuming I don't find any issues there I will consider changing the pump what I want to know is the pump coded to the car, for instance if was to buy a second hand unit would it be plug and play or would I need to get it coded to the car?
