USB device not recognised
Hi All
I have a 67 reg with Sync 3 infotainment system. I started to receive the usb device not recognised error on the display. This is without having anything connected. When I do connect nothing is found.
I have performed a sync master reset as well as removing the usb / infotainment system fuse plug. Neither have worked.
Not sure what else to try.
Thanks in Advance
No grit/dirt or anything in either the front or rear USB ports?
Otherwise it's still in warranty, Ford will be able to take a look. I'd grab a photo of the error if it isn't easily reproducable though.
