Powerfold upgrade
I have a 2016 fiesta I’ve fitted powerfold mirrors to. I have the fuse box with both relays in wiring with 10 wires to the 10 in the mirrors still indicates and moves glass but they won’t fold. The display doesn’t have the powerfold mirror line on it under chimes. Is this what’s stopping me and how do I sort it. Thanks
You will need to enable them in the ecu..... you can do this using a modified elm...
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F153598689098
and FORScan software....
https://forscan.org/
 Have you fitted the powerfold switch?
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F192880093912
Hey thanks for the reply, yes ive fitted the switch too and have an elm327 on the way. Is it pretty straight forward to do? Also my windows only go dow 3/4 of the way since fitting mirrors, what’s that about? Rod
Yes pretty straightforward once you have created an account and got your extended licence on FORScan website you should create the account whilst you’re waiting for delivery of your ELM327 as it will be useless without it.
On the issue with your window I’m not sure tbh you could try lowering your window down all the way, then disconnect the window switch and disconnect your battery, which may reset where your car ‘thinks’ the window is?
Is it all your windows that only go down 3/4 of the way? What happens when you re connect your old mirror/window switches?
Just the front are electric. I’ve put the old switch back on and it’s just the same. I may take the panels back off and just connect the mirror to see if they work then. All very strange.
Yes very strange, sounds like the window position needs adjusted or calibrated were your windows down when you disconnected the mirror/window switch?
No they were up when I swapped the mirrors, then when everything was back together and I went to check everything the windows only went down 3/4 of the way.
Ok so I’ve got the ELM registered with for scan and that’s about as far as I got,it lost me after that.lol is there a layman’s way of getting on?
