transit courier issues
Morning all, I'm new to the forum and have a few issues with my courier so in hoping i can get some advice!
1. Loss of power, i get a loss of power some times with no lights on the dash,I have to turn the engine off and on to reset, I have had it plugged in and got  P132B-22 turbo error code and
2599-00P turbo boost code
Garage said it's the sensor on the turbo but went 100% sure so I bought one anyway (£30) but not had a chance to fit it yet anyone else had this problem?
2. Rear offside door top lock catch doesn't engage when the doors shut, it doesn't seem to close and lock in when its shut I have had to put a flat head screwdriver in behind and hold the cable up as I shut it for the catch to actually catch.  I replaced it and it still is the same! Is there a known fault with this??
3. Sliding side door had dropped about 10mm at the front and door is catching and rubbing on the bottom bodywork but cant see how to adjust it back up a little.
4. Battery draining. Replaced it but still doing it, I have a feeling this may be the alarm pir sensor I have fitted in the back.
5 cabin fan/heater, when the fans on 1/2 speed setting it squeaks like mad and i noticed when i accelerate the fan sounds like it slows and when i take my foot off the accelerator it speeds up again,
All these things have started in the last 6 months!
I know there's alot here but any help would be appreciated
Cheers
