Ball joint splitter
Hi
Mk6.5 2008 fiesta
Looking to replace front wheel bearing.
I understand that I need to split the ball joint and was going to get a scissor type splitter.
They appear to come in either up to 19mm or 20mm to 60mm size.
Am I right in thinking I need the smaller of the two.
Many Thanks
I generally just remove the pinch bolt, use a small chisel to open up the slot and lever the control arm down. Ball joint splitters are a waste of time in my opinion plus you’ll be lucky to get in with a scissor type.
Stef123
Thanksfor your advice
Appreciated
I’ve got one to do on Friday night if you want some more advice I can take pics
