No sidelights or dashboard lights
When I turn my sidelights on no lights come on the dashboard and when I turn lights on the green dipped light doesn't show
Start by checking fuses behind glove box, glove box will have a decal on the back showing fuse location, but odd that all lights appear to be affected, so it could well be the switch.
are other lights ok eg the indicator telltale light on the dash and the blue High beam light?  might just need the plug taking off and putting back on at the rear of the speedo console due to bad connection. or the plug on the sidelight/ headlamp switch.  if the headlamps work then I doubt if the green dash light would have a separate fuse, but can't be certain.
All the other lights work fine
