Bad running
Ford fiesta 1.25 zetec petrol 2011 the car recently had a new water pump fitted. Ever since the car ran badly not much power and stall now and again. Had it diagnosed a lot of faults came up mainly abs faults cleared and stayed off after driving, new coil pack fitted. Car drives better and does not stall a bit juddery a low speed at times and the fuel consumption has gone up a lot  i think something has been missed when the pump was changed  any ideas thanks
does fitting a waterpump on one of these interfere with the timing belt, and hence chance the timing belt is one notch out on one camshaft for example. I don't know if that could have happened and if that would create these symptons.
Spot on!! That's what I'm guessing too. Timing sound wrong ,doesn't have to be a tooth out either as the timing on these engines can be anywhere due to the cam  pulleys are not keyed into the cams like conventional engines.
