Wheel Hub
Hi.
For the past year I changed 3 sets of discs and pads on my Fiesta.Went to the garage, replaced it under warranty.
Everything seems fine for 3..4 months then the steering wheel start to shake when braking.I went today and they tested the wheel hub and it seems it's bent and I want to try this option.
My question is, should I replace the bearing aswell or just the hub?
Are you sure the wheel bearing hasn't collapsed? I would check this first before replacing the hub as hubs don't tend to bend unless you have hit something
If it was the bearing then surely it wouldn't make any difference when you changed the hub.
