Rear Parking Sensors Issue
G'evening all , my apologies if I've just posted a topic already covered but here goes ...
Having recently removed the bumper cover chasing a suspected leak , I disconnected the multiplug for the rear parking sensors .
Since I've put all back together again , one of the park sensors is in 'having a canary' mode i.e. it goes straight to red on the screen when I select reverse gear .
Thanks in advance if anyone knows what is causing this .
Replies may well be delayed , it's a takeaway tonight 😁
Clean the sensor and connections up first 👍
Lucky you, for some reason, despite government rules to the contrary, all my local ones have shut! 😐
Update on sensors , cleaning them apparently wasn't the issue .
The full story is , the car's fitted with a Witter flange towbar and Witter bike carrier bracket .
I started and reversed (inches) without realising I'd left the main sensor plug disconnected . I didn't realise the full significance of the onscreen message until I went to refit the bike bracket .
Strangely enough though , yesterday the problem appeared to have righted itself.
Today it's back to red on screen .
Do I have any options other than take off the bike carrier bracket ?
I'm learning (the hard way) ...
Are the sensors angled ? When there are other things fixed on the back the sensors need to be pointed away in some cases
worth a look they may of been in the other way round .
Never had a problem even when I put the towbar on 18 months ago or so , the electrics a little later and the bike bracket was last to be fitted .
It's one of the middle pair , not angled . They all worked fine up until I moved the car with the sensors unplugged .
It appears that since then , the driver side sensor closest to bike bracket now'sees' the bracket as an obstruction .
Works fine with the towbar and 7 pin plug , even when I hang the bracket on with the bolts loose but the sensor sees red again when I tighten up the bolts ... 🤔
Btw , the Supermacs branches here are all closed , not sure about BurgerK etc but the independents are operating as takeaways only .
Have you tried powering it down for a bit to see if it resets?
easiest way disconnect the battery for an hour
Cheers , will try that .
I'll have to live with it til end of this lockdown though
I'll need to get the radio code first though as the Ford Audio book was missing when I bought the car .
Will let you know if it works .
Scratch that , I'm getting reaquainted with the owners manual (containing the audio info 😁 )
But I can't find any mention of a security code for the 'ice' ...
The plot thickens (and I'm talkin to myself 😯
They don’t have a code anymore
24 carat info , I just wasn't sure if there was/wasn't some other kind of factory fitted obstacle to newer type radios .
Thank you MrRedman 🍻
Well , I'm just in from reconnecting the battery .
It's still the same , goes straight to red .
Cheers all .
  • 2 years later...
Just to tie up the loose end here , my reverse park sensors now only respond as and when they should . I had the bike carrier bracket on the tow-bar altered . 😁
A valuable lesson learned ...
