Software issue
Long story short - 2007,2.0tdci, went to reflash my PCM as it had a shoddy remap done so wanted it back to standard. I've done this a fair few times on other fords so I've some experience.
Got the correct AS BUILT data and saved VID block first, double checked part numbers and got the correct software.
Using elmconfig I begin the update but as soon as it gets to the end it goes finishing...reboot...dtc clearing... then i get an error saying not supported.
At this point it's wiped my old map and the PCM is blank so no starting and PCM not communicating with other modules.
Elmconfig also says PCM type does not match the software (it does i've triple checked).
Any advice? I've been at it 3 days now and I've got a replacement PCM coming just in case. Thanks!
voltage when you programmed it?
check clean all multiplugs to the ecu and get it on a big power supply and try again?
12.5v+ had a battery charger on it the whole time 😞 have removed it and refitted it. elmconfig recognises the pcm is there but gets all the way to end of writing and errors out
try and grab the file again ?
try a different cable ?
I guess you didn't get a back up of the one it had?
tried another file just now, with an old elm327 cable i had. same error
the backup gives the same error
