Abs
Good evening.
My Wife's Focus 57 plate has just had the ABS light come on, before I take off all the wheels to clean the sensors, do all sides have them? Rears are drums.
We live very rural with a lot of crud and livestock by product on the roads, must be the cause of the light coming on.
Car is on 73k only
Thanks in advance of any info.
The rears will have them also, built into the Bearing/Hub assembly.
If you don't have any luck after cleaning them then it would be a good idea to invest in an adaptor and get set up with FORScan, which can read fault codes and monitor live data including the individual sensors.
The sensors pickup signals as the magnetic ring on the rear hub spins around. It might be water getting into the connectors that's causing the problem. Unplug the connectors and spray wd40 on them. That should push the water out. Or, like John says you can use forscan to read the signals on each wheel. You can show 4 graphs for the speed of each wheel as you drive. The graphs should all look the same.
