Rear Washer Not Working - HitFiesta
Hello, I have an 2014 Ford Fiesta Ecoboost Titanium, I have an issue where the windscreen rear washer doesn't come out whereas the front windscreen washer works fine, i have changed the washer pump, used air compressor can to see if the tubes blocked but it wasn't as air was coming out from the rear side, i had people say it could be the washer stalk arm as when you operate the front you can hear the motor but when doing the rear, you can't hear anything no sound whatsoever, can someone help me out or have come across this before? I have also checked the fuse too.
Has anyone come across this issue before?
Don't remember seeing it on a Mk7.5 so far, but it does sound like a faulty stalk if the fronts work fine.
Might be a blockage poke a pin in it see if it does anything
Update: Good news i managed to pick up a new washer stalk arm and it's now working!
