Fiesta ST Line 2019 Fog Light question
I was told that the drivers side front fog light wasn't working but after doing a lights check it seems that the drivers front fog light comes on when the headlights are on but only the drivers side and it seems intermittent.
The bulb is fine and the front fog lights when activated work fine.
Also, only the drivers side rear fog light comes on, not both.
I spoke to my next door neighbour who has a 2018 Fiesta and he has the same issue, only the passenger front fog light intermittently and only the passenger rear fog light comes on.
The owners manual doesn't state only one light comes on, is this a fault or is it standard?
Think you’ll find that these are your cornering lights. Try turning your steering wheel to the left while the headlights are on, and you should find the left hand fog lamp comes on.
The rear fog lamp is normal, there’s only a bulb in the right hand lamp. Not quite sure why your neighbours passenger side rear fog lamp comes on though.
Sent from my iPad using Tapatalk Pro
