Dim tail lights Mk7.5
My O/S tail light is dimmer than the other side. I checked and cleaned the connections on the lamp which looks ok, but I'm not sure how to check the earthing points or where they're located
Swap the bulbs over to the opposite sides. That will rule out it being a problem with the wiring or lamp holder.
chances are one lamp has blown in the past and been replaced with a dimmer lamp.
Are the brake lights both working? They're mixed bulbs, and I had this issue when one of my brake lights went.
