MK2 focus Powerfold Mirrors
Hi all, first post here but it's a great resource and has helped me loads up til now!
I'm trying to get powerfold mirrors from a MK2.5 working on a MK2 pre facelift - without DCMs.
The mirrors are on the car fine, I've done a test of puddle lights (via a tap on the footwell) and the final bit is to get powerfold working. I have the mondeo relay already and a couple of options switch wise (RS window switch with powerfold on mirror adjust and also the powerfold switch with alarm sensor disable). Has anyone done the wiring to get all this working together? Even just some pointers would be much appreciated just to get me going in the right direction!
Many thanks in advance for any tips/pointers
Cheers
Continued to work on this and now have the relay triggering via the alarm disable button.
There's an 11v pulse on the white/green wire from the relay (and a second pulse from the green/yellow wire) - I've run this to PIN 4 on the mirror connector which should be the trigger for powerfold but nothing is moving!
Figured it out. Pin 3 from the relay to pin 4 on the mirror plug. Pin 1 from the relay to pin 3 on the mirror plug. This gets the mirror folding in and out.
