Window and door
My near side window and door won’t open, I have checked the fuses. Can anyone help
Can you open the door from the inside of the vehicle or does it seem like the mechanism has come adrift
Can’t open it with any handle and the window won’t open either
I don’t know if you have a dead lock on your car connected to the central locking , because usually I would have thought you would be able to open from the inside unless you have a child lock switched on in the door shut . I would also check if you can see the wiring harness as it goes into the rear door from the near side front door opening because I’m wondering if some wire or connection has come adrift . I have managed on some vehicle’s to remove the door card to see what is happening inside the door,   It can be very difficult on some models without damaging the door card or trim
Thank you will try
