Focus Mk1 ABS issue
Looking for an ideas I have a 53 plate Mk1 focus, while dropping the rear frame I accidentally damaged the ABS wiring where the connectors are on the frame.  I have since repaired this and replaced the sensors for good measure, however I can't get the ABS light to turn off again.  Am I missing a trick or does this require a Computer hook-up, ideally looking to sort it without an expensive garage trip.
Disconnect the black negative earth battery cable for 5 minutes.Worth a try👍
Thanks will give that a go tomorrow see if it helps me out.
