2013 fiesta 1.0 ecoboost 100 ps no-start - intake cam 5 degrees out?
Hi all,
anyone any experience of this?
2013 Fiesta ecoboost 1.0 100 ps 140,000 miles suddenly lost all power on the motorway and had to be towed home.
I wasn't there so I dont know exactly what happened.
There are several DTCs that I have copied below.
Are any of these likely to prevent the engine starting?
PIDs when cranking on the starter report that the actual intake cam shaft is at +5 degrees when the desired camshaft position is 0 degrees.
Does that suggest that there is something wrong with the cam phaser or maybe that the sprocket has jumped a tooth on the belt?
Is that enough to stop it running?
Advice gratefully reveived from anyone wioth more experience than me!
===PCM DTC P000A:71-6C===
Code: P000A - A Camshaft Position Slow Response (Bank 1)
Additional Fault Symptom:
- Actuator Stuck
Status:
- DTC Maturing - Intermittent at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
- Test not complete
Module: Powertrain Control Module
===END PCM===
===PCM DTC P0420:09-E8===
Code: P0420 - Catalyst System Efficiency Below Threshold (Bank 1)
- Component Failures
Status:
- Previously Set DTC - Not Present at Time of Request
- Malfunction Indicator Lamp is On for this DTC
- Test not complete
===END PCM===
===PCM DTC P132B:21-6C===
Code: P132B - Turbocharger/Supercharger Boost Control A Performance
- Signal Amplitude Less Than Minimum
Status:
- Test not complete
===END PCM===
===PCM DTC P0106:62-6C===
Code: P0106 - Manifold Absolute Pressure/Barometric Pressure Sensor Circuit Range/Performance
- Signal Compare Failure
Status:
- Test not complete
===END PCM===
===PCM DTC P007B:26-28===
Code: P007B - Charge Air Cooler Temperature Sensor Circuit Range/Performance (Bank 1)
- Signal Rate Of Change Below Threshold
Status:
===END PCM===
===OBDII DTC P0420-C===
Status:
- Confirmed - malfunction is confirmed
Module: On Board Diagnostic II
===END OBDII===
===APIM DTC ===
Successful DTC reading, no error codes found
Module: Accessory Protocol Interface Module
===END APIM===
===FCDIM DTC U0155:00-08===
Code: U0155 - Lost Communication With Instrument Panel Cluster (IPC) Control Module
Status:
Module: Front Control/Display Interface Module
===END FCDIM===
===ABS DTC ===
Module: Antilock braking system
===END ABS===
===RCM DTC ===
Module: Restraint Control Module
===END RCM===
===PSCM DTC ===
Module: Power Steering Control Module
===END PSCM===
===ACM DTC ===
Module: Audio Control Module
===END ACM===
===IPC DTC B10EA:00-48===
Code: B10EA - Positive temperature coefficient heater
Status:
- Test not complete
Module: Instrument Panel Control Module
===END IPC===
===PDM DTC B1165:15-6C===
Code: B1165 - Left Front Puddle Lamp Output
- Circuit Short To Battery Or Open
Status:
- Test not complete
Module: Passengers Door Control Unit
===END PDM===
===PDM DTC B11F7:15-6C===
Code: B11F7 - Passenger Folding Mirror Motor
Status:
- Test not complete
===END PDM===
===PDM DTC U2101:00-6C===
Code: U2101 - Control Module Configuration Incompatible
Status:
- Test not complete
===END PDM===
===DDM DTC U2101:00-6C===
Status:
- Test not complete
Module: Drivers Door Module
===END DDM===
===BCMii DTC B1108:77-48===
Code: B1108 - Driver door central locking motor
- Commanded Position Not Reachable
Status:
- Test not complete
Module: Body Control Module
===END BCMii===
===GPSM DTC ===
Module: Global Positioning System Module
===END GPSM===
