indicator not working HELP
So my rear driver side indicator has stopped working tried changing the bulb and cleaned the contacts and still not working all the other lights are working its just that one that wont work 😒 any help would be great
When you switch on the right indicators does the front indicator flash twice as fast as normal (hyper-flash) ?
Assuming that your new bulb is correctly fitted and the contacts in the light fitting are clean, dry and making good contact with the bulb then the next thing to check is the Body Control Module (BCM) which is part of the fusebox located behind the glovebox. Check the BCM and all the plugs and sockets for signs of water and look for greenish corrosion on the pins of the connectors.
Swap the LH bulb over to the right first to rule out that the new bulb is faulty, wrong spec or fitted incorrectly
  • 1 year later...
Did this get fixed? What was the cause? The same issue has just happened to me.
20 minutes ago, Manxst said:
Did this get fixed?
Yes it did. No it didn't. Yes it did. No it didn't. Yes it did. No it didn't. Yes it did. No it didn't.
  • 8 months later...
Did u fix it if so how
So as not to repeat myself, please read my answer of 19th October 2022 it is the only answer you are going to get.
@Alan.rae OPW. Posted question 21st September 2021 and has not returned since.
@Manxst OPW. Posted question 19th October 2022 and has not returned since.
If you have a problem with your car, you would be best to start a new thread and give as many details as possible and I'm sure we will all try to help.
