Confirming Trailer Prep
Afternoon all,
I've had a good hunt through the forums and found some information regarding trailer prep and what not.
Will be ordering a towbar and wiring kit from pfjones today so went out to the car to confirm if I had TP and if needed the extension as well.
What I'm seeing in the car is this.
https://imgur.com/a/ET1AIlC
(let me know if the link is broken)
Fusebox with the loom coming out the bottom. Does not appear to have any spare plugs that from other posts seem to be what I would use regarding the vehicle specific wiring kits
So just to confirm things, I will need the full wiring kit along with an extension?
Such as this from pfjones?
https://www.pfjones.co.uk/ford-focus-estate-04-2011-09-2018-without-tp-13-pin-pf-jones-dedicated-wiring-kit.html
Or
https://www.pfjones.co.uk/ford-focus-estate-06-2011-09-2018-without-tp-13-pin-pf-jones-dedicated-wiring-kit-multi-fit.html
Not really sure why one is £40/£50 dearer unless it's the Led teailer lamp support
Any suggestions, I'm all ears.
Just want to confirm I'm on the right lines to get this installed and sorted
Cheers
Martyn
  • 1 year later...
Hi did you end up buying the stuff you linked? Did it work for you?
I am in the same situation as you atm. and want to make sure, what to buy 🙂
@MartynJ last visited this forum 17th January 2022
