Focus estate mk2 diesel
Hi - I have recently bought a used instrument cluster from the exact MY as mine. Told it should just be a straight swap which it seems it is except nothing happens when you turn the ignition key. Maybe an immobiliser fault. Is there a quick fix please ????
Not a straight swap.
Firstly you need to reprogramme the PATs immobiliser. You need a Laptop, FORScan software (with the full licence £10) and and ELM327 lead.
Download FORScan from here: https://forscan.org/download.html
Buy ELM327 lead from here: https://tunnelrat-electronics.fwscart.com/USB_Modified_with_switch_ELM327/p4541936_17045457.aspx
Then you can use FORScan to programme the PATs system.
The next problem you may have is adjusting the mileage. If your replacment instrument cluster has 'Less' mileage than your car then you can use FORScan to set the mileage to the correct reading. If your replacment has 'Higher' mileage you have a problem as you can not adjust the mileage backwards.
You could always just do like a lot of people and get your original instrument cluster repaired. Check out eBay for IC repairs, normally about £70. Or just do a Google search for dashboard repairs.
