Ford Fiesta Wheel nuts
Hi Guys, I've recently bought a 2016 Ford Fiesta for my son's first car. Unfortunately we had a puncture the other day and I had trouble taking the wheel off because the wheel nuts had been slightly rounded off. Apparently this is a common problem on Ford Fiestas. Does anyone know where I can get some tempered higher quality replacements?
Many Thanks
Simon
I hadn’t heard of this being a common problem. I don’t know where to get better ones, but in case someone does is it for alloy wheels or steel wheels (totally different style of nut). Were you using a hexagon or a 12 point socket / spanner?
Hi Isetta, It's for alloys.
Simon
The usual cause of rounded nuts is because they're made up of 2 pieces. A soft inner part and a hardened case 'crimped' ontop of it (this is where your 19mm socket goes). If a garage has used a nut runner in the past then these caps can fall off leaving an 18mm hex head. As these are soft they will easily round off, especially when a 19mm socket is used instead of 18mm.
As isetta says are you using a 6-point or 12-point socket to remove them?
I was using a 6 point socket but I tried a 12 point socket this afternoon which is much better. thanks for the reply.
