Hazard button and Lock/Unlock button backlight not working
Hello,
I have a problem with the backlight of my hazard lights button and lock/unlock button. The red backlight doesn't light up when I turn the lights on, but the buttons work very good as well as the yellow indicator for the lock/unlock button. The other buttons backlight work perfectly. Can someone tell what the problem is? Thank you very much!
Most likely reason will be a failed Led. Meter on diode range and apply the leads to a working LED. One way round it should illuminate. If not, try the resistance range . Once it does test the suspect one. If it is a Dark Emitting Diode, you can replace it. If not, look for a broken track on the PCB.
I will try. Thank you!
