Focus MK4 automatic gearbox problems
Yeah, it will settle back down.
Take my advice on the FORscan lead and doing your own regens
  • 2 months later...
good afternoon! did you fix the getriba malfunction? why did she slip? was the car broken into?
Edited by dalibor82
  • 9 months later...
ford focus 1.5 ecoboost 182 st-line x 2020 automatic
I Have the same problem. The message “gear selected will engage at low speed” appeared on my car’s screen, when I changed D to R and at the same time there was a strong vibration-shock in the car gearbox. I sent the car in a specialised garage since it has a guarantee. Three months later since they checked the car, upgraded it and restarted it, they gave it back to me, ready to use. Unfortunately when I drove it for about 300 kilometres, the problem showed up again. My car delivered to the garage again, they checked it and I was stand by, until the factory gave the order to change the car’s gearbox unit .I have already done 200 kilometres with the new gearbox and now the message showed up again in the transition from D to R. . The message turns off immediately after 2 seconds.This problem appears every time I switch from D to R! After the change gearbox the vibration-shock is a little bit softer. What’s the solution? I have read that other customers have also problems like this.
