Immobiliser flash code 24
Good evening. Ford fiesta 1.4 tdci 2012.
Can anyone give me the immobilizer flash code dtc list or know the definition of flash code 24. I presume its going to be related to ipc failure or a configuration issue. I'd like the dtc list, so that I can go through the motions though. Many thanks.
Hello Joseph, you need to use a Laptop with FORScan software, connected with a modified ELM327 lead and read the DTC from your vehicle.
The software can be downloaded free from:   https://forscan.org/download.html
and the ELM327 lead from here: https://tunnelrat-electronics.fwscart.com/USB_Modified_with_switch_ELM327/p4541936_17045457.aspx
Unofix. Will the for scan software work with vcm2 ? I have access to ids, but only lisenced for Mazda use.
Hi Joseph, sorry I don't know the answer. My thoughts is probably not, but I just don't know.
