Old w reg fiesta 16v zetec s
Feels like its running on 3 cylinders does not like gradients power drops off rincing the fuel
Try running it with each spark plug lead off in turn . If running on three then the one that makes no difference when removed is the cylinder with the problem. Don’t take leads on and off when engine is running
Have you downgraded your engine to a new 1.0 ecoboost ?
When was it last serviced, oil, oil filter, AIR filter and new plugs ?
Coil pack and HT leads are common to go down on these.
When was it last serviced properly?
How old are the plugs?
Follow isetta's advice.
Don't just change one plug or one lead, change the lot.
If you still have miss-fire after changing leads, plugs and coil pack it's time to start doing compression tests
