Harness for SYNC 1 to 3 conversion Ford Focus
Hi group, I hope you are doing well.
I am looking for a Harness for SYNC 1 to 3 conversion, I am not sure if this Harness will fit my vehicle version. It is a Ford Focus SE year 2015, SYNC 1. The panel that I have decided to adapt is the version that brings the Ford Focus RS (SONY Panel), which has a connection for the control panel and Hazard, unlike my current version of panel has only one connector for both the control and the hazard. Please can you guide me if this Harness is compatible with my version or if someone in this group has had good results using this version of Harness. From already thank you very much.
Bestycar arnés de potencia de conversión de 4 a 8 pulgadas, accesorio compatible con Ford SYNC 1, SYNC 2 a SYNC 3, Kit de actualización con conector USB de 4 pines, HUB multimedia|Reproductor multimedia para coche| - AliExpress
Are you just changing the front facia or are you going for the whole sync 1 to sync 3 swap? Might be an idea to post a picture or what you have now and what you want to have.
Hi @Nathan Buffery, thanks for answering my question.
I am looking for a change from SYNC 1 to 3, therefore it requires the Front Facia, I understand that this change entails modifications both in the harness and in the programming, since the Front SONY brings Control and Hazard separately.
I share the current and new Front.
ford focus front facia.pdf
There is someone on this forum that actually makes these harnesses up, but I cant for the life of me think who it is. I'm pretty sure they would be able to knock up a custom harness. If not, it would only be a case of adding three wires.
It's funny how things pop into ya head.......or is it just me? @Rowan112is the guy that builds the harnesses.
