Focus MK2 front wheel bearing replacement
Hi all,
I recently replaced the front wheel bearing on my MK2.
I nearly gave up half way through, but it all worked out in the end. Took a few days, but not bad for first time.
Here is a video of what I’ve done:
https://youtu.be/o4lGVe4i8Zg
10/10 for perseverance!  👍
Great video, I love vids like this where it shows how to overcome all the obstacles that arise due to age/rust! So many 'how to' have a pristine car where all goes like a text book. Shared your joy when the shaft finally came free! I'm sure you also changed the RHS one too as I was always told that you should replace both when one goes as they have both covered the same mileage...
Thank you.
I haven’t changed the RHS yet due to the weather, but I’ll do it soon.
I am sure it looked well easier when @stef123 done mines. Good job though 😁
I don’t agree with the theory that the other side should be replaced. Based on my experience of bearings failing on my cars I have only ever replaced the one that failed and the other side never failed during my ownership.
In over 4 decades of car ownership, I've only ever had to replace wheel bearings on 2 occasions, both times changing LHS & RHS at the same time, maybe I was wrong...
Maybe just making sure it doesn't but yes I had done just my driver's side one on my previous car and agree if it not broke don't fix it.
My rule on this subject is that if a failure occurs on a plane, then change both, if it occurs on a motor vehicle then just change one and leave the other untouched.
It hasn't let me down so far.
ScaniaPBman
  • 9 months later...
Brilliant video, and well done getting there in the end. It's convinced me not to even attempt doing mine, so thanks for that!
