Please help with codes
Hi everyone.
I have focus mk2 and was finding oil in my coolant, I had the oil cooler changed after head gasket tests passed. I have only been using car short trips
Now I have the red light on my dash and engine systems fault reading and accerlation reduced reading on digital display. I ran forscan on it and found a few codes does anyone know what's all these codes mean and do they reflect on the systems engine fault and acceleration reduced
RCM U1900-30
ACM P1628-60
GEM None
PCM U0155-61
PCM U0001-E1
PCM U0001-E1
PCM P1000-70
OBDII U0001-P
ABS U2012-A0
ABS U1900-A0
ICU U1900-60
please need your help guys
Thank you
32 minutes ago, madman said:
Hi everyone.
RCM U1900-30
ACM P1628-60
GEM None
PCM U0155-61
PCM U0001-E1
PCM U0001-E1
PCM P1000-70
OBDII U0001-P
ABS U2012-A0
ABS U1900-A0
ICU U1900-60
Thank you
You need to reset the codes. go for a drive and rescan for codes, many (potentially all) of those codes could be historic.
I see you have the u1900 code and another u code. These are cab bus loss of connection codes. Both can busses route through the instrument cluster. It may be faulty solder joints within the cluster.
This fault often throws up other spurious fault codes as the modules cannot connect.
if your car hasn’t had the cluster re-soldered, it may be this. Try slapping the dash above the centre of the cluster with the engine running and see if you get a reaction. Doesn’t always show but worth a try.
other wise clear the codes and re read them after the next fault appears as previous .
I took car for short trip to the shops about mile and half  and got back in the car and wouldn't start. I also notice the immobilizer light flashes crazy, with systems engine fault.
I had my laptop with me and forscan I reset the codes, taped the dash and got it started.
What you guys thinking please.
Was it the slap dash that brought the system back up?  If so possibly the cluster fault. Check the fault codes again .
about £100 to get the cluster resoldered/reconditioned
