Clutch gone
Hi all, got a problem with my focus and thought I'd try my luck here. Monday morning to get to work of all times I jumped in, started the engine but my clutch had gone right to the floor. Popped it back by hand but no pressure at all from the cylinder to push it back. Can start the engine, but cannot put into gear.  Had a look at my brake fluid reservoir and it definitely needs topping up. Had a look under the gearbox and have a nice big puddle on my undertray. Following the leak looks to be coming from the bottom of the gearbox. I think my slave cylinder seal has gone, what do you guys think?
Appreciate the help.
Sounds very much like it to me. Think most slave cylinders these days are inside the bell-housing, so the gearbox will likely need to come out to change it.
Dependant on the mileage, it could be worthwhile changing the clutch at the same time ??
Just 54k 16 plate. Was surprised it went to be honest. Good advice about the clutch as well 👍 may as well get everything done while the cars stripped. Was thinking about trying to sort it on my drive way but bit of a heavy job for that!
Is it a diesel with a dual-mass flywheel ??
If so, then you might want to consider changing that too while you're in there ??
(I'm no expert on DMF's so hopefully someone else could clarify whether it would be a good idea to change it ??)
My 15plate diesel with 55k on it, the pedal dropped to the floor also, and the DMF was rattling too, so new clutch assy, concentic slave and DMF supplied and fitted for £650, then 2 weeks later the clutch master cylinder went , so that got replaced too, and extra £200.
