Mk2 Focus Cooling system leak - Need help with clip on hose!?
I have had my coolant all leak out while driving, after nursing it home I have found the source of the leak. It's at a join to the T-piece just down from the coolant reservoir. Trying to get the system of pipes off to be able to cut the bands and fit my own hose as I can't get hold of the ford original part of the whole system.
I need help with this clip at the end of the pipe - what is the best way to undo it as I can't seem to get it to budge in any way?
Any help would be much appreciated,
Cheers 🙂
The bottom pipe connection?
Get your fingers behind the light grey piece and push it this way, then the pipe should release.
