What is this
Hi what do this little screw do on the throttle housing
It is a spring loaded throttle plate stop screw.
The engines types that use this type of throttle body do not have an Idle air control valve. Idle speed is fully controlled by the PCM by continuously adjusting the throttle plate. The spring loaded screw prevents the throttle plate from fully closing suddenly which results in the engine cutting out.
