Focus 2020 possible recall ?
See  extract below:   Is this a known problem suggesting recall for Ford Focus  dates below,  my Focus  Zetec Feb. 2020
Do I contact my local Ford Dealer ?    Do they have all recall details on their systems ?      Thank you.
Problem description: The engine wiring loom may be damaged by coming into contact with a bolt on the transmission housing. This could lead to an engine stall, increasing the risk of an accident. The Ford Focus models affected by this recall were manufactured between 31 July 2019 to 4 March 2020.
Check on etis. It will show if the recall relates to your particular car.
Thanks,  Etis shows message below, hence indicates no actions, I assume it would have indicated if any recalls outstanding.     Although I didn't log on just entered Reg. number to check.
Outstanding Field Service Actions
No Campaign Message(s) found
We will check for outstanding service actions on your selected vehicle, using your detected country, if this is incorrect you may not see the right information.
We have detected that you are in the: United Kingdom
Don't need to login . Not applicable to your car or already done prior to purchase if second hand car.
Thanks Ian.
