Second hand engine
Found a second hand engine for my mk3 1.6tdci (t1db)
New engine is bare, so will need to change everything over.
Does timing belt come off for diesel pump?
Or if I use pump on new engine does it need to be programmed/coded?
Diesel pump will not need to be programmed or coded, pump is driven by cam belt, assume you would fit new timing belt kit.
ecxcellent, thanks
yes will be looking to fit new belt while its out,
