Headlights
I own a 2012 focus titaniumx  2.0ltr I have problems  with self levelling  electronic  headlights getting condensation  in them and headlight malfunction  comes on dashboard  I have drilled holes in units to drain them and put silica  gel sachets in them which helped a bit any ideas
Normally when headlight get condensation there is water inside the headlights.
You either have a broken casing or the vent is blocked, most likely a broken headlight housing or seal.
Drilling holes into the headlight would just make it worse. Water will get in and heat up.
Find the seal, or crack that is allowing water in, once you know that you can fill it and after a few heat cycles the issue should resolve.
