mk2 focus headlight has condensation inside
my drivers side headlight has condensation inside , it passed its mot as still allows enough light but is there a cure for this, the passenger side is fine, it doesn't go away when i have the lights on at night
You will probably find it will stay there unless you removed headlamp and blow hot air in bulb hole with hairdryer.  Don’t do too mad , I caused a lot of damage to plastic doing this on a rear lamp
Shove a couple of silica gel packets in the back remove the covers and sit them in there there is plenty room and it works.
If all else fails, you can buy replacements on Ebay as cheap as chips from about £15 to £25! (One advantage of having an elderly mass produced car!)
