Power outlet problem
Hi all I have a 2010 mk2 ford focus and all is good with it but a issue came up that I can't seem to find any answer to online.
So basically the car has 3 power outles in the centre console 1 in the front one beside the hand break and one in the arm rest compartment. The one in the front works perfectly but the other two won't work at all I've checked and replaces the 109 fuse and the issue is still there. And when I checked the two outlets they are getting no power.
Would this still be a fuse problem or do you think it may be a wiring issue or something.
Any advice would be appreciated I've been searching all day and haven't found anything.
Have you checked fuse 119
Your car has 3 power outlets?? That's madness I tell you, madness! 🤣
I just check and replaced it to be sure but I'm still having the same problem
Yeahhhh 3 seems like a but too much but oh well if I can fix them I suppose I'll never run into the problem of not being able to charge my phone.... if I can manage to fix it that is
Then I think it's time to start pulling them out and checking to see if they are wired, and what the issue is with the supply.
